SailNet Community - View Single Post - furling and hallyard wrap.
post #3 of Old 07-05-2013
overbored
overbored's Avatar
Re: furling and hallyard wrap.
happens mostly when halyard is not tight you will need to undue the warp by turning the drum until the warp is clear. the halyard retainer is use to increase the angle of the halyard to the swivel. should be at 15 degrees. if you use a shorter head sail it should have a wire or rope pennant so the swivel will be at the same height
"GOLD RUSH" PRINDLE 16
overbored is offline
