SailNet Community - View Single Post - Loosing power Universal M25XP
post #8 of Old 07-06-2013
H2814D
H2814D's Avatar
Re: Loosing power Universal M25XP
Could be a few things actually. In addition to the above posts, how does the temperature look? An overheating engine will stall. Also, do you have a vented fuel tank? If the vent is clogged it could be restricting the fuel flow. After experiencing the problem, start taking the fuel cap off slowly and see if there is a suction of air sound. If so, find out where the vent is and make sure it is clear. You can also diagnose this one by loosening the cap while running and see if the engine speeds return to normal. Too many things to be sure, so get to work. :-)
H2814D is offline
