SailNet Community - View Single Post - Question Regarding Rudder S2 Model 8B
post #11 of Old 07-07-2013 Thread Starter
Re: Question Regarding Rudder S2 Model 8B
Originally Posted by deniseO30 View Post
Gary it looks very well made and built by someone that knew what they were doing. I Guess you could weld or drill a block of metal at the place on the gear where you would want the stops to be.
Hi Denise,
I ended up discussing as well with my local sailing shop and the owner suggested the following. I inserted two stainless steel clevis pins on the gear at the right location as stoppers and glued with epoxy glues. though not necessarily the recommended part, it works quite well as a stopper. I tested over the week-end it some pretty strong winds and it worked quite well. When I take out of the water in the fall, I will look at having some blocks welded, but this is a good start. I have attached an image.
Thank-you Denise for your initial response and everyone's comments and feedback,
Enjoy the rest of your season everyone,
GaryMasse is offline
