SailNet Community - View Single Post - Top 10 Sailboats Easiest & Best to Single Hand
post #24 of Old 07-09-2013
SailingJackson
Re: Top 10 Sailboats Easiest & Best to Single Hand
Originally Posted by Diceman View Post
Hello Sailor's
There are some great sailors on this site. In your opinion. What sailboats would you consider to fall into a top 10 category for easiest and best to single hand sail in a coastal environment. This would also include the possibly of living aboard? ( length 30 to 38 foot ) Use Up and Down the East Coast, Bahamas
Thanks
Diceman
When it comes to single handed operation, everybody seems to be talking about boat size and rigging. Single handed operation on open water is possible on nearly any size boat in open water, but if you want to single hand docking then you should look to some other factors:
  • Amount of freeboard
  • Keel configuration - as it impacts turning and sideslip
  • Propellor. Some give miserable reverse, others have good thrust in reverse
Essentially you want the boat to be strongly influenced by steering and engine (fwd and reverse), and less influenced by cross winds. Full keel does not want to turn and wing keel doesn't mind going sideways. Fin keel, low freeboard, and Maxprop or similar will keep you in control. Bow thruster is possible, but not needed unless other factors are working against you.
GJ
SailingJackson is offline
