SailNet Community - View Single Post - Should a Roller Furler be Hard?
post #18 of Old 07-10-2013
chef2sail
chef2sail's Avatar
Re: Should a Roller Furler be Hard?
One other thing I would check here is the angle of the furling line to the first sheeve or block. It may be why in the beginning the sail furls easily as you are pulling from a full drum, and as the drum empties your angle may be more acute and dragging.
Also when you let your sail out keep some pressure on the furling line as the drums fills up to insure more uniform overlap
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
