SailNet Community - View Single Post - Accessing waste pipe
post #5 of Old 07-10-2013
katsailor
Fresh water refugee
katsailor's Avatar
Re: Accessing waste pipe
Can you drill out the screws and pull the fitting with hose attached through the deck? Then you could release the clamp, install a new fitting and pump out the holding tank.
By the way I am facing a similar project, I can't remove the cap on the pump out fitting and holding tank is overfull. I ahve been dumping bleach into the system andf getting ready to simply open the cover on the tank and bail it out. Yuchh!!
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
