SailNet Community - View Single Post - Battening down for heavy weather
post #12 of Old 01-21-2007
georgellop
georgellop's Avatar
I have found that many portlights, even in classed boats, have the flange on the inside of the hull/house and are not through bolted but installed with self tapping screws. These portlights WILL be pushed a wave. Don't assume that because there is a flange around your portlight on the outside of the hull/house that this flange is an integral part of the portlight, in some instances it is just a dress/trim flange.
It is a good practice to have shutters cut, marked and ready to install. It might even be a good idea to install some of the shutters prior to an ocean passage. Aluminum plates are often used.
George Llop
S/Y BANDOLERA
1958 41' PHILLIP RHODES BOUNTY II
BETAMARINE
DIESEL PROPULSION & GENERATORS
Mobile: (786) 443 5567
Fax: (786) 221 3986
georgellop is offline
