SailNet Community - View Single Post - The final solution - what I came up with regarding auxiliary propulsion (pic heavy)
post #58 of Old 07-11-2013
Frogwatch
Re: The final solution - what I came up with regarding auxiliary propulsion (pic heav
Nice looking bracket bracket.
Your bracket is the same I have for the kicker on my Tolman Skiff. Over ayear of bouncing around on the road, it finally cracked the fiberglass because of the stress at the bottom of the bracket. Your bracket bracket is not much bigger than the footprint of the bracket. I now use a piece of 3/16 G10 about 1" wider but 2" longer between the bracket and hull to spread the load. You will also need such.
Frogwatch is offline
