SailNet Community - View Single Post - The final solution - what I came up with regarding auxiliary propulsion (pic heavy)
Old 07-11-2013
chrisncate's Avatar
chrisncate chrisncate is offline
Taco Whisperer
chrisncate is on a distinguished road
Re: The final solution - what I came up with regarding auxiliary propulsion (pic heav
Originally Posted by Frogwatch View Post
Nice looking bracket bracket.
Your bracket is the same I have for the kicker on my Tolman Skiff. Over ayear of bouncing around on the road, it finally cracked the fiberglass because of the stress at the bottom of the bracket. Your bracket bracket is not much bigger than the footprint of the bracket. I now use a piece of 3/16 G10 about 1" wider but 2" longer between the bracket and hull to spread the load. You will also need such.
I wound up using a stainless backing plate of the same footprint. That, in combination with the very thick transom glass lay up on the A-30 seemed to do the trick (the A-30 transom is small and thick, and held the bracket vane with ease and no perceivable flex). I only used a 2hp Honda 4s on the bracket, and I removed two springs as I couldn't easily compress the bracket downwards with such a light load on it. It worked extremely well.
