SailNet Community - View Single Post - Aristo Blue Awlgrip Pictures
post #24 of Old 01-21-2007 Thread Starter
1970Columbia34
1970Columbia34's Avatar
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
Originally Posted by loomaz
How did you prepare the surface. It looks like you have some kind of undercoating that you are painting over. Or did you just sand down the old finish completely. I"m interested in the prep you did before the actual application of the paint.
I started by cleaning the boat with a wax a grease remover the filling any low spots, or scratchs with west sytem filler. next sanded the entire hull with 220grit paper on a 5" random orbital. Next I cleaned agian and tacked the entire hull off, plus taping anything that needs to be covered. then primed the hull with awlgrip 545 primer. then sanded the primer with 320 grit then clean and tack before applying topside paint.
this is the short version it makes sound like this is a weekend project, when its really extensive and god knows how many hours. just take your time cause the prep is the most important thing.
1970Columbia34 is offline
