SailNet Community - View Single Post - Yanmar Transmission Clutch Problem
post #21 of Old 07-12-2013
Northsman
Re: Yanmar Transmission Clutch Problem
Originally Posted by ncapener View Post
Hello,
I have a 3 HM 35 engine with a KBW10 transmission.
Recently the clutch started to slip, now it does not engage at all.
I took the transmission out and the cover off. I am looking inside the housing at two shafts with gears on them, a shift fork and what appears to be clutch plates on the larger shaft.
I would like to repair/ replace the gear box myself. How do I proceed ? Drawings or pictures available anywhere? I think, I can get the parts. I am not a mechanic, but I have a good set of tools and have taken a VW transmission apart once and changed the synchro rings....
Anybody done that job and can help?
If not possible to repair, Is there a way to lock the gear box in forward to get home???
Thanks,
Neal
I'm haveing the same problem as you With the transmission (gearbox) model KBW-10 mounted on an old 1979 model yanmar 20QM20 motor. Where did you get the gearbox manual and how did you solve your problem? In advance tks from Norway.
Northsman is offline
