SailNet Community - View Single Post - Yanmar Oil Pressure Pegged
post #2 of Old 07-15-2013
fryewe
fryewe's Avatar
Re: Yanmar Oil Pressure Pegged
What weight oil? If it is too heavy (viscous) the pressure will build up in the manner you are seeing until the oil heats up.
If the weight is right I think it's more likely your pressure sender is "off" than the relief valve is at fault.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
