SailNet Community - View Single Post - Yanmar Oil Pressure Pegged
post #3 of Old 07-15-2013 Thread Starter
DrB
Re: Yanmar Oil Pressure Pegged
Originally Posted by fryewe View Post
What weight oil? If it is too heavy (viscous) the pressure will build up in the manner you are seeing until the oil heats up.
If the weight is right I think it's more likely your pressure sender is "off" than the relief valve is at fault.
I am using the same oil I have used since day 1, Rotofella (sp?) 30 Wt. If Pressure sender is "off" wouldn't it not work once the motor is warmed up? When the motor is warmed up, the gauge appears to read fine.
Thanks for the response.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
