SailNet Community - View Single Post - Bow connector for forestay?
post #1 of Old 07-15-2013 Thread Starter
jwir3
1974 Venture 17
Hello -
I have the following situation on the bow of my V17 (see image). The forward eyelet is used to attach the forestay to the deck. I think the previous owner put this in, and he used it for a number of years by the looks of it.
It works fine, but my concern is that this eyelet isn't sturdy enough to hold the forestay. I'd like to replace it with something that comes up through the deck and has a backplate underneath. Since I'm currently restoring all of the woodwork on the boat, I thought this might be a good time to replace this eyelet, as well, with something more sturdy (since I have to remove the piece of wood anyway).
My question is - what are these pieces of hardware that attach to forestays called? I can't seem to find anything that works for what I need it. Does anyone have recommendations for what might work better for a forestay connection point? What should I be aware of when installing it?
BTW - The connector just to the aft of it is used to connect to the jib tack. I assume there is some formula for the best place to connect the tack of the jib in relation to where the forestay meets the deck, but my intuition tells me that the previous owner simply eyeballed it. So, any advice on how to place that would be helpful, as well.
I intend to replace the same bow wood piece (I'm not sure what it's called - like an above-board mini bowsprit?) with one that is very similar, but restored, and possibly more intricate in its woodwork. So, if my guess is wrong, and the eyelet will work fine, then I can simply replace it on the new piece of teak I'm going to install.
Thanks!
~Scott
jwir3 is offline
