SailNet Community - View Single Post - m25 alternator question
post #6 of Old 07-15-2013
Maine Sail
Maine Sail's Avatar
Re: m25 alternator question
Originally Posted by SSBN506 View Post
You reminded me and pointed out the problem. I set up the battery monitor and celebrated it with the battery's at 80% and the manual tells me I have to celebrate at 100%. So I assume that is why my BM-1 is off I think.
Yes the batteries must be at 100% SOC before you can calibrate it. You can determine a "good enough" full point by measuring less than 2% of the 20 hour Ah capacity flowing into the bank. With no DC loads on, and you see less than 5A flowing into the bank, you can then do a manual re-set. I find monitors are much more accurate when synched manually and done often. 1-1.5% of the 20 hour rate is an even better "full point" but when out cruising you'll rarely get there.
______
-Maine Sail / CS-36T
Maine Sail is offline
