SailNet Community - View Single Post - Yanmar Transmission Clutch Problem
post #25 of Old 07-16-2013
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Re: Yanmar Transmission Clutch Problem
Originally Posted by Rusty123 View Post
The referenced Yanmar tech bulletin says to leave the transmission in neutral during sailing, but that the shaft can be locked (with an add-on device) if the user doesn't like the prop rotation noise.
Question: what does prop rotation noise sound like? I get a faint squeal or whine (a little like a bad bearing) from my transmission when under sail in neutral. Is that sort of noise normal?
Often times a free-spinning prop will sound a bit like a low humming noise. There may be a bit of a squeal (if your listening to the transmission more directly, such as via an open lazarette), kind of like a car gearing down. If in doubt, take a look at the shaft to see if it's turning.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
