SailNet Community - View Single Post - Docking for Dummies
post #17 of Old 07-17-2013
Alex W
no longer reading SailNet
Alex W's Avatar
Re: Docking for Dummies
[quote=emcentar;1060194]
Originally Posted by Alex W View Post
I have the same boat as you.
Can you better explain your docking situation? This is what I've got:
Docking Diagrams - AlexAndChristine's Photos | SmugMug
I don't have a picture, but my boat is in the same situation as yours, with the following exceptions: my pier is a little finger pier (no jumping on the boat last minute) and my exit is in the opposite direction. Prevailing winds are usually from port.
You have the same problem that I do then.
When you are trying to turn you need to get the bow through the wind. The wind pushes excessively on the freeboard of the boat, and is overpowering the turning force that you can get with the rudder.
You can reduce the effects of prop walk by doing a big burst of reverse, then putting the engine back into idle/neutral. That does help the reverse slow speed turning of the boat. Or you can go out backwards, which I think does work better in many situations on our boat.
I love the 28-2, but that freeboard really does have some costs.
Alex W is offline
