SailNet Community - View Single Post - What do you have on your cabin sole?
post #36 of Old 07-17-2013
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: What do you have on your cabin sole?
I went to Boulter Plywood and bought a sheet of 3/4" Teak & Holly Plywood for the bilge covers, and a full sheet of " for the rest of the soule. The O'day 35 uses the FRP floor pan of an O'day 34, except that it is normally covered with " teak & holly ply. The 3/4" substrate is great in that the bilge covers do not flex at all.
After cutting the plywood to fit, I coated the back and sides of each piece with 2 coats of epoxy. Then I added a strip of aluminum L bracket from Home Depot to the edges, to prevent them from being damaged from butting / chafing against each other.
I finished it with 4 coats of Minwax Satin Poly (the admiral does not like the gloss look).
eherlihy is offline
