SailNet Community - View Single Post - Trailer light genius needed
post #2 of Old 07-17-2013
Lateen Luffer
big dreams, little boat.
Re: Trailer light genius needed
Sounds like there may be some mis-wiring. Check that the correct wire is being used as the ground at each of the trailer lights. Then be sure that the proper wire is being used for the ground at your loom. Sounds like a reversal of something. If your car has separate bulbs for the turn signals then you need one like http://www.amazon.com/ACDelco-TC198-Professional-Trailer-Connector/dp/B00559JYZI/ref=au_pf_ss_14?ie=UTF8&Make=Toyota%7C76&Model=Corolla%7C1013&Year=1996%7C1996&carId=001&n=15684181&s=automotive. ~LL
Lateen Luffer is offline
