SailNet Community - View Single Post - Moisture around chainplates
post #7 of Old 07-18-2013 Thread Starter
nestorph
Re: Moisture around chainplates
Bert (or others):
How are the chainplate deck plates attached to the deck? Are they through-bolted or screwed in? You'll save me time digging past the headliner if they're just screws.
Thanks
Originally Posted by bvermeer View Post
The chain plates on the Islander Bahama 30 are known to leak on a regular basis. I lift the small deck plates every spring and re-bed them with a Sikaflex sealer. I have also used 3M5200 but it's a real bear to get off if they ever leak again. And there is enough flexing with the chainplates when sailing that they will leak again. Same as the windows! If the chainplates have been leaking a long time the interior bulkheads will be stained where the water has run down the plate and into the bolt holes, getting under the varnish. The deck is plywood cored and unless the leak has been going on for years, should be good.
Bert Vermeer
s/v Natasha
Sidney, BC
nestorph is offline
