SailNet Community - View Single Post - Trailer light genius needed
post #7 of Old 07-18-2013 Thread Starter
TBApollo
Re: Trailer light genius needed
Wow that tester is dirt cheap. I'm going to pick up both the tester and a voltmeter tomorrow first thing.
Unless the factory mixed up wire colors, everything is hooked up right. I suppose the new tools will clarify that.
I re-drilled the trailer side ground today because I found that whoever set it up before me had set it on an uneven seam-- thought for sure I had it--but nooo!
Not sure what to do if/when I find a problem with voltmeter other than trace wires for damage but as I said, all wiring and lights are brand spanking new.
Will post what I find...thanks for all the help!
TBApollo is offline
