SailNet Community - View Single Post - Suggestions for a stiff boat
post #6 of Old 07-18-2013
RainDog
Not Finished Yet
RainDog's Avatar
Re: Suggestions for a stiff boat
Just speculating based on very little knowledge here, but......
You will get a lot of stiffness in at least two ways: form stability and a large righting moment.
Form stability requires a wide flat bottom. Luckily for you, most modern production monohulls have exactly this. Especially the shoal draft boats.
A large righting moment a low heel angles would come from a canting keel, water ballast, or a deep keel with a heavy weight on the end. Probably none of these are that practical for you.
With a modern flat bottom boat, I would think you could quite easily stay at < 12% in most cruising situations with a little practice.
I would look for a boat with flat aft sections and a high ballast/weight ratio.
RainDog is offline
