SailNet Community - View Single Post - How to connect a Standard Horizon GX2100 AIS VHF to a Raymarine RL-70C plotter
post #7 of Old 07-21-2013 Thread Starter
GNU
Re: How to connect a Standard Horizon GX2100 AIS VHF to a Raymarine RL-70C plotter
Joevar,
That's interesting.
I'm guessing it's still related to the original issue (the voltage difference in the signal).
Do you have access to an additional resistor that you can add in series? The common resistors have quite a bit of play in them so you may not have enough. An alternative if you don't have an additional resistor onboard is to add a long and thin cable. That also adds resistance. If that works then just go back to Raidoshack and get a resistor when you have time.
GNU is offline
