SailNet Community - View Single Post - southcoast 22 keel problem
post #2 of Old 07-21-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: southcoast 22 keel problem
Here is the spec for the South Coast 22':
SOUTH COAST 22 sailboat specifications and details on sailboatdata.com
I suspect that your swing keel weighs 500 Lbs. which should drop easily.
What often happens with swing keel/center board boats is that marine growth jams up the slot or trunk where the swing keel lives. You are going to have to get into the slot with a flat metal tool and try to knock as much growth out of there as you can. I do this every year for the center board slot on my Tartan 27'. I get piles of barnacle shells falling out when I do this.
A reasonable tool for this job is a flat metal bar or a small wood or sheet rock saw.
Everybody has one:
CalebD is offline
