SailNet Community - View Single Post - Yanmar Oil Pressure Pegged
post #12 of Old 07-21-2013 Thread Starter
DrB
Yanmar Oil Pressure Pegged - Part II
Okay,
So I went to the boat today. Changed the oil filter, pulled the sender, and put in new oil; in that order. Sender looked fine, not plugged with stuff. I didn't have a mechanical pressure gauge to try, so I reinstalled the sender and jiggled the wire some.
After I turned the key to on, and before I pushed the start button, I looked at the oil gauge and it was pegged, without the motor on. The other gauges hadn't moved. I am more convinced now it is a electrical problem or the oil sensor itself.
Thanks all for the advice.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
