SailNet Community - View Single Post - Anchor Setting Woes
post #57 of Old 07-22-2013
Maine Sail
Maine Sail's Avatar
Re: Anchor Setting Woes
Originally Posted by MedSailor View Post
I'm just having a bit of fun, no worries.
The bolts on the mantus are galvanized. You ARE right that the bolts are another potential point of failure and another point to inspect. Personally I feel they are so overbuilt that it's not an issue, but I will have to inspect them once in a while.
What about welds, like on a rocna (the mantus has welded joints too)? Welds can go bad if not done correctly and are "technically" a point of failure too and should probably be inspected. That said, I never really worry about welds except for stainless...
MedSailor
Keep in mind this simple fact.
Each of the FOUR bolts holding the shank to the fluke on a Mantus is larger than the SINGLE/ONE screw you have in your shackle......
______
-Maine Sail / CS-36T
Maine Sail is offline
