SailNet Community - View Single Post - Charles Industries C-Charger
post #1 of Old 07-22-2013 Thread Starter
Lubrdink
S/V Glenn E
Lubrdink's Avatar
Howdy fellow Sail-netters,
Here's hoping you might be able to answer my question about my charger which seems to have gone belly up. It's a Charles Industries C-Charger Model CI-1208A. We were on the boat last weekend and had no juice on the port battery (a recently purchased Interstate deep cell). The starboard batter was fine when the Perko was switched to it. So it was the Perko, the wiring or the battery. After doing some checking and recharging, the battery is fine and works through the Perko. So I moved to the charger. I noticed that the needle didn't move so suspected it wasn't charging. I pulled it brought it home to do some bench testing and found it was working but the output only 10.71 vdc.
So...it is putting out voltage but not enough. Would that low voltage be enough to keep it from charging the battery at all? It's original to the boat (1970 Newport 27) so no complaints if it's dead but thought I'd let you all hold forth on your thoughts if you would care to.
As always-a picture (or two) is worth 1K words.
Blessing to you all,
"Sailing with a hero"
Honoring S/Sgt Glenn English, Jr, Congressional Medal of Honor for heroism that cost his life in Viet Nam, 9/7/70.
Newport 27 built 1970-Hull # N270088
Lubrdink is offline
