SailNet Community - View Single Post - Ignition problem, stumped!
post #4 of Old 07-23-2013
erps
the pointy end is the bow
erps's Avatar
Re: Ignition problem, stumped!
A common problem with the Catalina 34 was a fuse located in the engine compartment that powered the instrument panel/starter switch. The fuse would blow and everything was dead at the instrument panel as a result. Put a 12 volt test light on the backside of your instrument panel to your ignition switch and see if you have juice.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
