SailNet Community - View Single Post - Ignition problem, stumped!
post #11 of Old 07-23-2013
kd3pc
kd3pc's Avatar
Re: Ignition problem, stumped!
Originally Posted by postwarcomet27 View Post
Where would the the ignition panel fuse be located in the engine compartment? Closer to the batteries, or closer to the panel? I left the boat for the day, so I can't look behind the panel and follow the wires. I will check it tomorrow to see if it's blown. Do the keys have to be turned "on" to have power to the blowers? I have a seperate pull knob switch for the blowers. It seems like this fuse could be the problem. Ammeter is working on the panel, so I know it's getting juice. Just could be sending that charge nowhere if the fuse is blown I guess.
Thanks everyone.
since it is a gas engine, you may start with the blower switch, you may have to have that switch ON, as an interlock to get ignition to come in. IF there is no blower activation, then NO ignition. Most gas engine boats I have worked on or used did not require the switch to be on, as that could cause problems in the presence of gas fumes/vapors. You want to run the blowers a few minutes PRIOR to an attempt to start the engine. IE, the blowers are powered at all times, just pull the switch, no key required.
What was your start sequence, begin to end, when there was only the charger providing power?
Fused links are usually fairly close to the battery, but are not easily identified, certainly a smaller gauge, perhaps what looks like a fat #10 or #12 wire.... A trouble light or a good voltmeter is going to be required to indicate whether power is present.
kd3pc is online now
