Unless the teak deck was recently done or the boat is extremely new, it is most likely a mechanically fastened teak deck... which can cause serious water intrusion problems... One easy way to tell if it is a mechanically fastened deck is to look for the bungs covering all the screws...  A glued deck won't have bungs, a screwed down deck will.
Not exactly right, (I am really sorry to disagree with you), but it depends on the construction method.
Mine is screwed onto fiberglass deck with screws that have the cover as you mention, and is also glued with special whatever I don't know the name.
The screws were filled with sealant before tighteneing, and DO NOT protrude on the other side (interior) of my FG deck.
