Mr. Keith -- In terms of applying a barrier coat, you usually will find that people recommend the product they used to barrier coat their boat. In my case, I used MAS epoxy, so it is in fact an epoxy barrier boat. I sanded the bottom down to bare gelcoat, dug out the few blisters that were present, filled in those divots, faired the bottom and applied 6 coats of the MAS. No problems since then. As others have said, the bottom paint you choose is a separate deal from the barrier coating, and there are other threads on that topic alone.
Good luck!
SailorMitch Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
