SailNet Community - View Single Post - Are ALL Sellers LYING MORONIC DOUCHBAGS??
post #75 of Old 07-24-2013
davidpm
davidpm's Avatar
Re: Are ALL Sellers LYING MORONIC DOUCHBAGS??
One big one was a leak in the water tank. There was no indication of leakage during the survey.
That's off you would think it would be more likely to leak from the bottom than from the top.
Unless it is leaking from the bottom because of the extra weight.
Be sure to tell us when you find out what it is.
davidpm is offline
