post #4367 of Old 07-26-2013
bobperry
grumpy old man
Re: Interesting Sailboats
Perhaps you missed it on the other forum:
My 63' FRANCIS LEE, the "sliver" project was moved from the shed yesterday to the yard where it will be finished. Beam is 9.81 feet. My client has previously owned a Swede 55 and a 30 square meter. He likes narow boats. The hull is red cedar strip planking and the deck is composite glass and foam. The entire interior is CNC cut and foam cored It was built intact out of the boat and then dropped into the shell in one pice. The fit was perfect. Draft is 10 fet with a welded steel fin and a lead bulb. Total displacement will be 19,000 lbs. At this point in time we are spot on with our weights. Launch should be in two months.
File Type: jpg BP 62 Sliver Sail Plan 2011-03-18-small.jpg (27.0 KB, 26 views)
Bob's Blog ....
bobperry is offline
