SailNet Community - View Single Post - Removing Hot Water Heater
post #31 of Old 07-27-2013
BMLipiec
BMLipiec's Avatar
Re: Removing Hot Water Heater
RainDog,
I struggled with that one too. There just isn't a good spot. I will probably install it in the same compartment. Although i have thought about putting it in the engine room too, because it will keep the cable run short and you will probably never run the charger and the engine at the same time so heat shouldn't be a problem. I don't plan on using the charger much though. With the solar panels currently installed (100 watts) I haven't needed a 110v charger as they keep both battery banks topped up.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
