SailNet Community - View Single Post - Companionway Hatch Slides Tight?
post #5 of Old 07-27-2013
CaptainForce
CaptainForce's Avatar
Re: Companionway Hatch Slides Tight?
I'm assuming that you have an "L" shaped rail that fastens to the deck on each side of the side and coverrs the lip of the sliding hatch on each side. Consider the use of two thin (ca. 1/16th inch) polycoarbonate strips. One wider strip would be on the bottom and fastened under the rail and the slide. The second, upper strip, would be positioned only under the rail. This would give you a new slick surface and an added 1/16th increase in the gap. An added check may be available. Do you have a hasp for a lock that attaches the slide to a fixed point? Does this hasp for the lock close without rasing the slide for a proper fit? This hasp position may indicate something that has changed.
Take Care and Joy, Aythya Crew
CaptainForce is offline
