SailNet Community - View Single Post - Twist
Thread: Twist
post #18 of Old 07-28-2013
Jeff_H
Moderator
Jeff_H's Avatar
Re: Twist
One thing that I might add is that instead of flagging your mainsail because you are trying to get the boom to the centerline, you might try really blading out the sail as suggested, minimizing twist, put on gobs of mainsheet, but lowering the traveler so the sail has a flatter angle of attack. You will get a little more drive, less drag and more style points. The other thing in a lot of breeze you can move your jib leads slightly aft and add twist to the genoa. This should reduce heeling and weather helm and may let you use your mainsail more effectively.
Jeff_H is online now
