SailNet Community - View Single Post - Westerbeke/Universal Diesel Problems
post #18 of Old 07-29-2013 Thread Starter
stowe18
Hello all..
I wound up replacing the oil sender and the oil pressure switch- and that did nothing. Had a mechanic come (i was out of ideas) and he was just about to rip apart the engine after about 2 hours of scrounging around.. I had one more idea before he did that. Look at the vacuum gauge. That was the problem. It was leaking air into the fuel supply. So I took it off and stuck a screwdriver into the hose and engine started. Works fine! I guess a lot of maintenance work was done in the process..
Thanks for all the suggestions!!
1986 35' O'Day Mears Point Marina Kent Narrows, MD
stowe18 is offline
