SailNet Community - View Single Post - SSB Antenna wire
post #1 of Old 07-30-2013 Thread Starter
sailak
Crealock 37
sailak's Avatar
Dock
SSB Antenna wire
My boat has an Icom M710 SSB with tuner installed. The back stay is insulated and used as the antenna. I have been able to receive but very scratchy and somewhat distorted. I have not gotten any reply when sending so suspect I may not be putting out. As I started looking at things I found the wire to back stay connection was done with a poorly fitting clamp and the wire pulled out of the clamp. For the interim I used a small hose clamp to secure the wire to the back stay. As I checked further I found the wire was crimp butt spliced just above the deck. The splice fell apart when I removed the tape covering it. I think my antenna may be sub par.
What kind of wire should I use between the back stay and the radio?
How should I attach the wire to the backstay?
I'm clueless about this stuff, advice/tips appreciated.
Thanks.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
