SailNet Community - View Single Post - SSB Antenna wire
post #3 of Old 07-30-2013
aeventyr60
aeventyr60's Avatar
Re: SSB Antenna wire
Originally Posted by btrayfors View Post
Dale,
Use GTO-15 wire between the tuner and the backstay. This is high-tension, single conductor wire....essentially neon light wire.
At the backstay, one good and easy way is to use stainless steel wire clamps....the U-shaped ones with two nuts on them. Get a third nut (most are metric sizes these days) and fit a good ring terminal on the end of the GTO-15 wire to slip over one of the clamp studs, and secure it with the extra nut. This makes a very strong connection which can be easily removed, inspected, cleaned, or replaced.
Bill
To help maintain the integrity of the connection you can wrap the entire clamp(after connecting the antenna wire) with butyl tape. I used some heat shrink before butyl tape became the in thing.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
