SailNet Community - View Single Post - Give way when hoisting the main?
post #9 of Old 07-30-2013
JomsViking
Splashed
JomsViking's Avatar
Re: Give way when hoisting the main?
Originally Posted by Alex W View Post
You aren't in the rules for the stand-on vessel if your motor is on. As long as your motor is on and cooling water is spitting out of the motor you are a power boat and power boat rules apply. It doesn't matter if you are neutral or in gear.
When the motor is off you are sailing and sail rules apply.
If you have a motorless vessel then you would have right of way over a powered one. However if you have a motorless sailboat there is also a very good chance that you raised sail at the dock.
The definition of a power driven Vessel is
"b.The term 'power-driven vessel' means any vessel propelled by machinery;"
So You're not correct, unless the engine is propelling the Vessel (i.e. in gear) you're not a powerdriven Vessel.
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
