SailNet Community - View Single Post - Repair of Teak Toe Rail
post #9 of Old 07-30-2013 Thread Starter
casey1999
casey1999's Avatar
Re: Repair of Teak Toe Rail
Originally Posted by xort View Post
How big are these areas? Epoxy is brittle. Filling small cracks might be OK but larger voids could be problematic.
Also, make sure it's a thin epoxy that will soak well into the surrounding teak and bond with it.
I like epoxypoducts.com
Tons of good info on what their different products can do plus some good tech support. Plus prices are way lower than others and just as good or better. Every one of theirs is amine free, no blush.
Some of the teak rail has cracks running down the length of the rail that would be no more than 1/16" inch wide. some voids are maybe 1/2 inch diameter. There are a vew areas where the teak has been worn down to the screw that used to be counter sunk and plugged. This is an area where I might try to build up the railing, although I might have a bonding problem and will probably not be able to build back the full 1/2 inch, but maybe at least cover the screw heads.
casey1999 is offline
