SailNet Community - View Single Post - Main and Jib Trailing Edge Flapping
post #5 of Old 07-30-2013 Thread Starter
casey1999
casey1999's Avatar
Re: Main and Jib Trailing Edge Flapping
Originally Posted by jimgo View Post
Do you have a topping lift? Have you eased off of it so the boom takes the weight of the main? Do your jib sheets run through blocks or the stanchions? Could that be playing with the shape of the sail, especially at the foot?
Topping lift is eased and slack so boom is loaded by sail and main sheet only. The jib sheets run through blocks that are on track slides so I can adjust sheet angle. I have made adjustments of the block slide with no real change of the flapping. Also changing jib sheet tension cannot get rid of the flapping. Even with the jib reefed and sheeted in tight I still get a flapping.
casey1999 is offline
