SailNet Community - View Single Post - Cutlass bearing replacement
post #8 of Old 07-31-2013
Kutter
Re: Cutlass bearing replacement
Why don't you just bed bearings on epoxy as a clearance fit? no press required. This is done on many bearing installations. Removal is also easier, if it's in a metal carrier just heat the carrier and the epoxy softens, if it's in GRP or wood you can coat the bearing in release wax before it's fitted then it can be split away from the carrier with a sharp narrow chisel. This method is proven to be quick, easy and reliable.
Kutter is offline
