SailNet Community - View Single Post - Repair of Teak Toe Rail
post #16 of Old 07-31-2013
Plumbean
Re: Repair of Teak Toe Rail
Originally Posted by casey1999 View Post
...Also, the screws holding my toe rail are not visible from the inside of the boat. There is another glass layer that covers both the toe rail fasteners and the deck to hull joint. Therefore, disturbing the fasteners opens up a can of worms.
Same setup here. They added a layer of glass on the underside of the hull-deck joint, effectively creating a long box running the length of the boat. IIRC, the old rail was screwed, not bolted, into the joint, and we did the same thing with the new one. No leaks.
BTW, another option if you have a really bad section is to just scarf in a replacement in that section alone.
Plumbean is offline
