SailNet Community - View Single Post - Do I have to predrill before running screws into fiberglass
post #18 of Old 08-01-2013
fryewe
fryewe's Avatar
Re: Do I have to predrill before running screws into fiberglass
Originally Posted by paul323 View Post
If you drill through gelcoat - perhaps not in your case - start off by drilling in reverse. Reduces the likelihood of chipping.
This is a good tip. After drilling the small hole in the glass use a non-pilot bit whose size is about the size of your chamfer and - with your drill in reverse - start the chamfer by smoothing the edge of the hole before using the countersink/chamfer bit. If your large bit has the appropriate face angle you may be able to complete the chamfers with the bit eliminating the use of the chamfer bit (and higher potential for chipping the gel coat).
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
