SailNet Community - View Single Post - Confused about which oil weight to use
post #10 of Old 08-02-2013
Send a message via Skype™ to DixeyJulie
Re: Confused about which oil weight to use
Thanks Smurphny,
Last week, I ran the motor in idle, in neutral for about 25 minutes, it had plenty of water flow in exhaust, Then, I thought it might be getting too hot,
So I reved it to 2500 for 15 seconds, then lowered RPM to idle in 5 seconds,
and shut it down. For some reason, the motor was very HOT, and it froze for about 2 hours. Since, I did not know it froze, I tried to start it after about 20 minutes after I shut it down, and It blew the starter aluminum cast shroud over the gear teeth into two pieces. Luckily, since this happened once before,
I had bought two, to have a spare, and replaced it. No aluminum cast pieces went into the flywheel cavities. But, does anyone know why it got so hot,
while running in idle?
DixeyJulie is offline
