SailNet Community - View Single Post - Survey questions
post #2 of Old 01-25-2007
sailingdog
There are different levels of surveys... there is an insurance survey, which is generally less comprehensive than a buyer's survey. Not all surveyors do insurance level surveys...and if you're buying, you wouldn't want one anyways.
Yes, it is a good idea to get a separate engine survey.
Whether it is better to do a dry or wet survey is a crapshoot. Some things are better seen with the boat in the water, others with the boat out of the water. For instance, checking out the rudder, keel and hull condition is far easier with the boat out of the water... but checking the packing gland and thru-hulls for leaks is easier to do in the water.... and so on...
I am not a marine surveyor, and will let those who are answer you more in depth... Hey CardiacPaul... n00b has questions for ya.
sailingdog is offline
