SailNet Community - View Single Post - Confused about which oil weight to use
post #23 of Old 08-04-2013
DixeyJulie
Send a message via Skype™ to DixeyJulie
Re: Confused about which oil weight to use
I will removed the anode above the transmission and water flowed out freely there, I did not find any impediments inside, but, I did not do any scratching inside with a clotheshanger, I will do that and see what I can find out. I will also locate the freeze plugs and check those areas. Where is the second anode location? I do not see another one in the 3GMD diagrams. Also, the 3GMD runs on the raw water from the thruhaul valve. No radiator.
Thanks!
DixeyJulie is offline
