SailNet Community - View Single Post - Confused about which oil weight to use
post #26 of Old 08-04-2013
Send a message via Skype™ to DixeyJulie
Re: Confused about which oil weight to use
Thanks to both of you for your comments. I have read that I should run at the top RPM to blow out carbon, once in a while for about 15 minutes. So that is when I hit the 7.3 knots at 3600. I do usually run at 2900 and am doing about 6 knots then. I do not notice any smoke of any color coming out at that speed. So, I am wondering if I should get a mechanic to tear it down to inspect the cylinders, and hone them, and to replace the rings, -since it seems to run fine most of the time. I want to take a trip to the Bahamas, and I certainly do not want to go there with the idea that I might have a motor that is ready to die on me. How many hours labor does it take normally to tear it down, hone it, replace the rings, and you know? THanks!
DixeyJulie is offline
