SailNet Community - View Single Post - how to adjust jib leads on toe rail
post #2 of Old 08-05-2013
Barquito
Barquito
Barquito's Avatar
Re: how to adjust jib leads on toe rail
May not be efficient, but, you can tack, adjust the block, then tack back. Or, also not really easy, you could keep going, tie another sheet onto the headsail, put another block on further back, (grab the one from the windward rail), run it through, cleat it off, and finally take the original off. Final idea: If the jib does not hoist the full length of the forestay, you could change the lead angle by changing how high the jib is hoisted.
Bristol 27
Cirque
For Sale
Valiant 32
Barquito is offline
